HELP pc doesnt post
Go to solution Solved by Attack Helicopter,
UPDATE
So i took it to the tech and he plugged it in, not turning on, he turns his back and boom pc turns on, and it wasnt working bfr that since i tried it right bfr taking it to him, left it on for like 3 min to see if it wasnt just taking a while to boot, so i take it back home and its working perfectly now, gotta love technology.
So yesterday i was using my computer just fine, went to sleep then wake up and it doesnt post anymore, the fans spin tho their rgb is off, the ram and gpu rgb's are on peripherals all turn on except my monitor thats says no signal.
Specs:
2x16 gskill trident neon rgb expo
B650 aorus elite
Ryzen 7 7800x3d
Gainward rtx 3080 10gb
Corsair cx 750
2 ssd's from kingston a sata and m.2 (dont know the exact names)
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/
3 minutes ago, Attack Helicopter said:
The dram light is turned on and thats it
That means there's a ram error
Try testing with just one stick in A2 slot
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16415325
4 hours ago, Attack Helicopter said:
Already tried it, did nothing
Okay, I assume you tried each stick solo in that slot.
What else have you tried?
Reseat CPU? Clear CMOS?
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16415599
Ngl to you i might know the issue just not how to fix it, cuz ive had the exact same issue bfr and took it to a technitian friend of mine, he tested everything took the pc apart etc etc, but idk what he did at the end something to do with the fans that made it work, i might just have to take the pc to him next wednesday.
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16415659
Can you contact him and ask what he did? Or at least have him explain what he's doing the next time you take it to him? Get some learnin' and expand your skillset
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16416152
UPDATE
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16416296
On 5/21/2024 at 10:08 AM, Attack Helicopter said:
for like 3 min
I really hope you mean 30 not 3. DDR5 memory training can take more than 30minutes on some boards.
My partner has a build that takes 3.5 minutes to boot every time because the memory is slightly out of spec.
https://linustechtips.com/topic/1570931-help-pc-doesnt-post/#findComment-16417338
