MSI OPTIX MAG271CP not vesa compatible
Mangoman8667
Hello I recentley bought this new monitor and found out it isn’t vesa Mount compatible. Is there an adapter I can use or smth?
I think that you should find an adapter on the internet. Not sure about it tho..
It certainly is VESA mount compatible. 100x100mm.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
I tested my vesa mount. It works on my Dell monitor but not my MSI monitor
Ok thank you I’ll check online
The mounting holes are underneath the vertical plate of the stock stand that "snaps" into the back of the monitor.
If your VESA mount does not fit, then you're doing something wrong, or it's broken, or it's not a 100x100mm mount.
You'll find adapters for other MSI monitors, but not this one, because it doesn't need one.
