PC Randomly Not Turning On
Solved by SpookyCitrus,
4 minutes ago, Alexb770 said:
How do I do this if I can't get the PC on? Like I said I can't get it back on. The motherboard will flash briefly after flipping the PSU switch back on, but that's it.
Unplug the powersupply from the wall, remove the CMOS battery from the motherboard(Silver circular battery usually under the GPU or towards the lower end of the mobo) and let sit for 5 minutes or so, or hold the power button for 20 to 30 seconds. Put the battery back in and try powering the system on again.
