Buying advice on DDR4 RAM running in gear 1 (Alderlake)
Solved by Hairless Monkey Boy,
The relevant question here seems to be this. Have you ever overclocked/tuned your RAM? Do you like to, or do you think you will like to and want to try getting into it?
If not, then just grab the cheapest 3600 CL16 kit. That'll be fine.
If so, then both of those kits you picked are B die, so either will be good for tuning, with the 3600 kit being a better bin (and so will probably but not definitely achieve higher clocks at the same timings and/or voltage or the same clocks at better timings and/or voltage).
IMO there is no point buying fancy RAM if you aren't going to tune it yourself. There is hardly any performance advantage, so the real benefit of more expensive RAM is the experience of playing with it.
