Best cooler for 5900x?
lwzi
I can't decide if I should get air cooler or AIO? I'm thinking about getting be quiet dark rock 4 air cooler I also have in mind noctua nh d-15 air cooler which one is better? Is there a big difference in temperatures between 70-100$ air cooler and 100-150$ AIO.
If you mean Dark Rock Pro 4 vs D-15, they are about the same.
Depends on the case.
It is easy to mount an AIO so that it gets cool fresh air just from the intake of the case, can't do that with an air cooler, which has to share the space with the gpu. But if your case has good ventilation, it is a wishwash.
Also by running an AIO as an intake, you will raise the temp of the gpu, by blowing all that hot cpu air on top of it, so truly a choose your compromise situation.
I only see your reply if you @ me.
This reply/comment was generated by AI.
Thermalright FC140 does well on my 5900X. Better than most.. That would be my recommendation.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
I personally like the Noctua U12A. Pretty much D15 performance with way better aesthetics
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
