What's the difference between ALC1220P and ALC1220-VB?
floe
Go to solution Solved by Spuriae,
The datasheets aren't public, but there shouldn't be any difference in output quality. For Realtek, the letters at the end of the model name usually refer to the physical chip form factor. For instance the ALC1220 (no P) is a QFN56 package, while the ALC1220P is a QFN48. There is likely no practical difference between the two other than the number of pins. (Maybe a few GPIO changed or GND/power rearranged, or an extra feature removed; nothing that would affect performance of the chip itself).
There doesn't seem to be any consistent meaning to VB at Realtek. I've seen it refer to different digital signalling formats or newer processes, but never changes in core functionality. (The ALC5672 and ALC5672-VB, for instance, are identical as far as I can tell). Very unlikely to have any difference in output quality. If there's any change to the analog circuit, Realtek usually likes to start a new model number.
The clearest example of this is the RTL8211.
RTL8211E-VB: 48-Pin QFN, 2.5V/3.3V signalling
RTL8211E-VL: 48-Pin QFN, 1.5V/1.8V signalling
RTL8211EG-VB: 64-Pin QFN, 2.5V/3.3V signalling
-CG means lead-free. Every ALC1220 should be -CG, whether or not it's marketed as such. A -T at the end, e.g. "CGT" means supplied on a tape and reel.
ALC1220X/S1220/S1220A are Asus-specific SKUs. No clue what they've changed. Probably something very minor, like having them pre-flashed at the factory so they don't have to reprogram the chips after assembly. The ALC1220X has marginally worse SNR specs in Asus marketing, but that could easily be due to something like locking it into amplified rather than line out mode, or them reporting the specs for the board as a whole rather than the chip itself.
Keep in mind that since the different SKUs are all so similar, a motherboard manufacturer using an "ALC1220P-VA3-CGT" may just call it an ALC1220 in their marketing materials.
TL;DR: most likely zero practical difference.
While looking for a motherboard, I've come across numerous versions of the realtek alc1220 codec, and I so far I haven't been able to figure out what the difference is. Does anyone know? all help is appreciated
It might differ because of different board manufacturers. I don't know tho. Could be a minor difference but it doesn't matter too much. Just my guess.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 9700k, GPU > RTX 2070 8gb, RAM > Corsair Vengance 2x8gb 3000mhz, Motherboard > Z390 Gigabyte Aorus Pro Wifi, Storage > 1TB HDD & 2pcs of 500gb M2 SSDs, Cooling > H100I Corsair Platinum, PSU > Corsair RM750X V2
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wired
Mousepad > Glorious 3XL extended
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
