Painted my CPU cooler ^^
TaiTeX
Just now, PC Builder2345 said:
This is not bad of a paint job not gonna lie
Thanks man 🙂
I painted it with a spray can for 6 Euros 😄
What would you suggest me buying to pimp up the looks of my pc?
1 minute ago, PC Builder2345 said:
I would had some RGB Strips so the look look great 🙂
I will try that out thank you my freind 🙂
That fan turned out great!
A bit of cable management. The USB header can probably be brought in lower and behind the fans. Hide most of the cable behind them. Get as much of the other cables out of the motherboard tray as you can.
The 24 pin and 8 pin power wires, you could always do up all black with a sharpie to get rid of the multi color cables.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
The USB3 Cable is so stiff and bad to move this is the best I can do I think
Cable extensions, L shaped usb3 connector (can be found cheap on Aliexpress), RAM with heatspreaders, a better CPU cooler, zip ties.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Love the painted cooler shroud!
Very nice and tidy little build. Definitely something you can be proud of.
That USB 3.0 cable sure is a pain, so I wouldn't sweat it. You could get an extension for it (there are low profile ones that use all black ribbon cables, much easier to fold).
The other front panel connectors are managed very well.
The only little tip I can think of is running the cables from the rear fan behind the motherboard (as in between the board and the motherboard tray).
It is very annoying to do on a finished system, as you have to take the board out of the case, so only do it if you have plenty of time/a different reason to take out the board.
You also have to be careful not to puncture the wires with any of the pins sticking out of the back of the board, but this type of fan cable can usually fit into that gap just fine. You can always wiggle it a bit before screwing the board in to make sure it isn't pinched somewhere.
IMO, the end result is usually worth it:
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
A gpu backplate
13 hours ago, NOV654 said:
A gpu backplate
There arent any for the GTX 1050
I would need to make one myself I love DIY solutions:)
  Reveal hidden contents
Wow thank you for the amazing Feedback that's the nicest Thing someone ever said to me 🙂
do you have access to a 3d printer or laser cutter?
if not ask a local high school who should have one.
If you want to go DIY you could make one out of acrylic (probably white to match the rest of the build).
Just get a big enough sheet and cut it down to size, put some double-sided tape on the GPU cooler screws and stick it on.
It will "insulate" the back of the card, but it shouldn't really matter with a 1050.
You could even get some vinyl sticker material (forgot what it's called) and either have someone cut a design out of it, or carefully trace a design with a craft knife.
Better than trying to make one out of aluminium, having to cover most of it with a plastic sheet to prevent shorts, buying thermal pads and having to figure out a mount with enough clamping force to squeeze the thermal pads without bending the panel.
I will do that thank you for the Perfect advice:)
STATUS UPDATE
I painted my GPU White I think it fits the build way better 🙂
I didn't even think about painting the shroud, it fits so well!
I feel like now it doesn't even need a backplate, as the white shroud and black PCB ties it very nicely with the motherboard and CPU cooler.
Yes it looks very good 🙂
And thank you again for your very nice comment:)
I mounted an 240mm AIO from coolermaster I think it looks perfect 🙂
Temps are great too 🙂
UPDATE
I send back the coolermaster AIO and I got an new one from Corsair its the Corsair H100x its way better than the coolermaster one 🙂
STATUS UPDATE:
I got some white psu cable extensions they look very nice ^^
