Hello! I had spit coca cola on my keyboard on the right side of it, it works but its wierd when i click on it the keyboard that i have is Death stalker razer and i dont know how can i clean it i dont know how i can open the keyboard plssss help me!!!!
https://linustechtips.com/topic/141830-i-neeed-help/
Take off the caps and clean them Individually
https://linustechtips.com/topic/141830-i-neeed-help/#findComment-1893511
If its a membrane keyboard you may have issues cleaning it as the aren't really designed to be disassembled and maintained.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/141830-i-neeed-help/#findComment-1893543
does it work with memory keyboard or what its called, i dont have mechanicle
nope
https://linustechtips.com/topic/141830-i-neeed-help/#findComment-1893617
buy a new keyboard
https://linustechtips.com/topic/141830-i-neeed-help/#findComment-1893647
Flip keys out with small screwdriverUse soft, damp tissue to clean under keys and dry one also. Then place keys back. If you are lucky thats all what is needed. If you are unlucky, certain keys stop working.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/141830-i-neeed-help/#findComment-1897922
