Xbox Series S/X Controller right stick issues
Solved by bmx6454,
extremely common on the series x/s controllers, elite series 2 controllers, and one s controllers(somewhat less). only thing you can do besides rma is expand the dead zone settings untill the drift is no longer an issue, depending on how bad it is, it might still be quite playable. ultimately i would send it in for rma as it is a defect on m$'s end, have to do the same for my elite series 2(second time..).
