Help me figure my bottleneck? (Cyberpunk 2077)
Solved by SkilledRebuilds,
11 minutes ago, Vice Fielder said:Well, I'll fiddle some more with the settings, though like I said, lowering things just been dropping GPU usage.
With a RAM (Speed/Timing) bottleneck, you'd be better off using higher details and a lower overall avg fps to maintain a more stable less fluctuating AVGFPS without "larger drops" when playing. 2-4 sticks of 2933Mhz (Dualchannel) would still bring large benefits to "frame consistency" / "less variability" in gameplay over 1x2400Mhz stick, and will be less dollars than having to splurg 3200-3800 (if your mobo supported them and they were a choice) 2 sticks of 2933Mhz would be where I'd start my planned upgrade.
