Will my GPU bottleneck my 8 years old CPU?
Solved by jaslion,
There is always a bottleneck. That isn't the problem
The problem is that when a part of the system is getting so behind it's causing you undesirable performance. So are there games you play where you are having bad performance (framedrops, stutters,...)? This is quite common in new games with just a pure quad core.
Featured Topics
2
4
18
2
JFRStudent ·
Posted in Photography and Videography1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
