asrock b450m pro4 motherboard with r 5 5600x
Solved by Skiiwee29,
Its super easy to update the BIOS provided you have a compatible BIOS. Depending on how old the board is, it may not have a compatible BIOS. But if its a new board, it will likely have a compatible BIOS. Asrock usually puts a sticker on the motherboard BIOS chip with the BIOS version it ships with so you can always check that.
Featured Topics
me255 ·
Posted in New Builds and Planning7 -
Alienized ·
kasdashd ·
Posted in Folding@home, Boinc, and Coin Mining1 -
4
remo233 ·
Posted in New Builds and Planning4 -
ALBORLIN ·
Posted in Servers, NAS, and Home Lab0 -
2
