Best Air cooler for i5-12600k
Nostalgia7
Which one is better?
Cooler Master Master Air MA612
Noctua NH-U12s
Gigabyte Aorus ATC800
I'd ignore the Gigabyte, the CoolerMaster and Noctua are about the same. So just get the cheaper one.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Thanks for the help! 🙂
Personally don't recommend buying a Coolermaster cooler for an Alder Lake build at this time. It'll work just fine provided you get the upgrade kit (I use one too) but in case you don't get it included in the package, it can be a royal pain to get one separately from Coolermaster. Their support is horrid and the upgrade kits tend to go out of stock frequently in their online shop. (Bonus points in case you don't live in the US or Europe)
As far as I know it comes with the bracket kit included 😄
Noctua NH-U12s
U12S is kind of a pointless cooler in my opinion. It is overpriced for what it is. For that price, get a Dark Rock Pro 4. If you can save up another $30, get a Noctua U12A or D15. They perform similarly but the D15 will be much quieter. The U12a is more aesthetically appealing and has better ram clearance.
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
Scythe Fuma 2 or Deepcool ak620. Costs the same as u12s but perform much better. Both have lga1700 kits available for about 5€.
@Nostalgia7
If in US (ordering from main Amazon site), Thermalright Peerless Assassin 120. At $42, costs less than Scythe Fuma 2 or Deepcool AK620, but performs the same. Also has LGA1700 kits available for similar price.
BeQuiet makes some really good and nice looking coolers. Especially if you're into black designs.
