cooling small supermicro board
Solved by BiotechBen,
1 hour ago, mineblaster said:I had some other stuff to fix with it too
But I had a look around and found a little 60mm noctua fan
And zip tie it to the heatsink and tidy some of the wires out of the way aswell.
It works much better with that fan on it. it's summer time here in nz so 30 degrees celcus for the first temp and I think it was 25 when I had done the second one the second measurement
Yeah, 30C ambient is not great for passive cooling
