Replacing Case Fans
Samoyed
Here's a weird question.  I just had to replace case fans in a PC. Reconnecting the new power lines to the fan power spots on the MB made my blood pressure go way up and bad language come from my mouth.
Does someone make a tool to grab the little rectangular 3 or 4 pin connectors and guide them down thru all the mess to that sweet spot on the motherboard?  Needle nose pliers just don't work.
Who makes it and where do i get it?
Thanks.
it would be easier to take out the gpu and whatnot.. and guide them behind the mainboard tray and out a grommit where it should and in?
and magical tools like that are only delivered by santa and the tooth fary..
if you need to guide it behind the other cable crap.. you didn't do a good job in the first place?..  or just use a huge ziptie and pull it through. .
8 minutes ago, emosun said:
They make super long needle nose pliers
true.. that are those medical personal have available at an operation table too right?.. those would be best 🙂
Doctor doctor.. OPERATE! 😄
No i usually see mechanics have them for grabbing small things way inside of a car
