Just because I guess...
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1880324
It's like force, you don't say few force you say low force
but if you said i had very few frames per second talking about a certain period then itd be alright ^^ but still sounds weird saying few and much, low and high is normal
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1880346
@Rorgash has it correct, it's to do with the actual number of frames. If the number is lower, you say low FPS, and when the number is higher, you say "high FPS". You could also use Minimum or Maximum FPS when you are talking about the extreme ends of the FPS range a particular game/video will run at.
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1880350
I don't know. I guess we've become used to saying it that way?
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1880448
Much FPS? Are you trying to sneak doge into things again!?
My Rig "Corsair air 540, MSI Z87-G45, i5 4670k, EVGA ACX 780, Gskill sniper 2x8gb 1866 memory, Corsair CX500m modular 80+ bronze, corsiar h100i, toshiba 1.5tb HDD." / Peripherals "Acer H226HQLbid Black 21.5" (Main monitor), Acer S200HLAbd Black 20" (auxiliary), Razer blackwidow ultimate 2013, razer naga 2013, razer goliathus 444x355 speed edition, Sennheiser HD8 DJs"
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1882040
high number, low number? and both is used depending on scenario
Actually he has a point. A frame is an image. So when you say you have lots of images you don't say high or low you say I have lots of pictures. We need to start the Lots of frames Revolution
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1882957
im agreeing with the low fps and high fps? Did you even read what i typed?
i was saying the opposite of what you said in terms of fps not force or another variable. did you even read what i said.
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1883345
Not really no and to be honest I couldn't care less
then why even bother quoting back. just leave if you couldnt care.
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1883529
Why is it low fps and high fps instead of few fps and much fps? few and much sounds much more logical to me.
low framerate - high framerate (few framerate - much framerate?)
few frames per second - many frames per second would work though.
144Hz goodness
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1886492
it should be many shouldnt it.
There were many frames per second. for high
and there were few frames per second for low.
Im confused...
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/140863-low-high-fps/#findComment-1886642
