HUAWEI 4G CPE Pro 2 B628 Support mesh?
Jezzdabezz
I want to set up a 4G router for my nan, she has a big house and needs a mesh system. I was going to add one on and disable the built in Wi-Fi but then I found out that they could have mesh built in and you could just add nodes. Most other Huawei routers have a HiLink mesh system but the 4G CPE only has one reference to it in the product page to the fact that the WPS button can also be used to pair nodes.
If it does then where can I find nodes that I can connect to the router?
