Can't choose between 5700G and 5800X !
Solved by Chris Pratt,
The GTX 950 is still going to be better than the onboard graphics, so since you have a dedicated GPU, the 5800X is a no-brainer. The 5700G actually only has the CPU performance of a 5600X, with less cache. It also only supports PCIe 3.0, whereas the 5800X has PCIe 4.0 support. You're trading a lot with 5700G for the iGPU you won't need anyways.
