Help! MSI B550M Pro incompatible bios
Solved by GuiltySpark_,
B550 needed a BIOS update at launch to support Ryzen 5000. These days its rare to get one that hasn't been updated though I suppose its still possible if its a less popular board that might have been sitting in a warehouse for a while. Either do the loaner program @RONOTHAN##mentioned, buy and return a cheap Ryzen 3000 or take it to a local PC shop and ask if they'd be willing to to use a compatible CPU of theirs to update the BIOS.
Morale of the story is buying a B550 board with CPU-less USB BIOS flashing was a good idea. That board being on the lower end does not have that feature.
