Sorry, I know this isn't a maths forum but I need help on my high school math problems. How would you wright the formula for a graph that extended in four dimensions? (3 conventional dimensions + time) I need to figure out how to write a formula for a point in 3 dimensions that corkscrews through the z axis as time passes.... Please help!
Build: Fx-8120@4.1ghz,  Gtx770@1.0ghz,  16gb Patriot memory,  Cheap case from thermaltake
https://linustechtips.com/topic/140443-maths-help/
Google....?
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/140443-maths-help/#findComment-1874315
you just add another line like:
X1             T1               S1
X2    +     t T2     +     S S2
X3             T3               S3
X4             T4               S4
And i think you need a third paramete too. dunno exactly.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/140443-maths-help/#findComment-1874433
This thread is getting mathematical.. im abandoning this thread
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/140443-maths-help/#findComment-1874448
Think of the x and y axes as having a point on a circle that moves around as you move through the z axis
for a point on a circle with radius 1 the formula for any point on this circle will be x = sin(angle) and y = cos(angle)
x = sin ( a ) and y = cos( a )
a is the angle made between the point and the circle center, and the y axis
therefore if you substitute some multiple of z as the value of a, the point will rotate gradually through the z axis to make a corkscrew
x = sin ( mz ) and y = cos( mz )
a larger value for m makes a more regular corkscrew cycle then in order to make a sense of time you simply alter the phase for each value of t. This is so that the position of the point on each of the planes in the x and y axis have rotated to produce the effect of a rotating corkscrew
therefore you simply substitute a multiple of t into the two equations as follows:
x = sin (mz + nt) and y = cos (mz + nt)
a larger value of n will create a more rapid rotation of the corkscrew
if you wanted a different size for the corkscrew, or even an elliptic corkscrew, you just put a value for r1 and r2 in front of the sin and cos like this:
Final formula: x = r1 * sin (mz + nt) and y = r2 * cos (mz + nt)
https://linustechtips.com/topic/140443-maths-help/#findComment-1874623
https://en.wikipedia.org/wiki/Parametric_equation
Look under 3-d example. I suppose that's what you're looking for.
However that's not a graph in four dimensions. I think you mean the image of a function going from an interval to the three dimensional room. The graph of this function would be four dimensional, but we obviously can't draw in four dimensions.
Edited by TideRower
https://linustechtips.com/topic/140443-maths-help/#findComment-1875007
No, they don't. Screw maths.
The stone cannot know why the chisel cleaves it; the iron cannot know why the fire scorches it. When thy life is cleft and scorched, when death and despair leap at thee, beat not thy breast and curse thy evil fate, but thank the Builder for the trials that shape thee.
https://linustechtips.com/topic/140443-maths-help/#findComment-1875073
What grade level math is this... I'm in 11 University math. Never seen this before... xD
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/140443-maths-help/#findComment-1875146
Ive taken engineering math and Ive never learned this.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/140443-maths-help/#findComment-1875181
