Hey all I'd like to know if there are any cheapo wired earbuds that pack a punch. I'm not sure if it's possible but I'd like to know if any have that 3D type of sound with some base. I just prefer wired for now not really looking to spend $100+ on true wireless earbuds and most are crap that don't sound that great or break easily.
I know most will probably recommend IEMs which I'm cool with just wondering if there are any other cheapo that might have some rich base I can turn up the volume to. 🙂
https://linustechtips.com/topic/1401767-best-wired-earbuds/
Not really. You're talking 8-10mm drivers here. There's only so much that can be achieved in that form factor.
I've pretty much switched exclusively to headphones for this reason, just using earbuds when I'm out and about, working out, etc. If you want to sit back and relax with some good sounding tunes, you need headphones.
I know it's not what you're asking for, but if you like bass, I can wholeheartedly recommend Skullcandy Crusher Evos. They can literally rattle your skull.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15192262
Interesting combo. So we have an IEM denouncer that recommends Skullcandy products 🤔 ... not sure how to counter that other than with this:
Highlighted in orange is the harmon target, which is already getting bad press from the enthusiast audiophile community. In the blue is the Skullcandy Crusher Evo's.
Largely bloated and muddied bass response, with no real sense of speed nor tactility. A sloppy mess by all regards to audio, and a consumer-oriented signature meant to please those who haven't experienced the superior end of audio. Kinda the line in the sand between two people, the "Whoa, you guys should try these! I'm hearing so much more than I used to" and "wHoA, iTs GoT gOoD bAsS" (which is objectively false anyways, because it's quantative over quality).
What's wrong with the harmon target:
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15192464
Moondrop Starfield, Moondrop Aria. Look no further.
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15192485
Please don't give this guy (BBGAR) views. Even if his arguments against the Harman Curve were legitimate (which they are not), the threats of physical violence that he sends to people in the community combined with his history of stealing gear make it hard to in good conscience promote his content.
The Harman Curve has shortcomings (E.g. the HD800 has high pinna interaction and should not be used as a reference headphone, their HATS has inaccurate coupling at high/low frequencies, floorstanding speakers are an inappropriate neutral reference, the filter frequencies are arbitrary, etc.), but this video addresses none of them, instead choosing to focus on an argument that a blind test with 250 participants isn't sufficiently rigorous and that instead a personal target curve, created sighted with a sample size of 1, is superior on the basis that the presenter is the best listener on earth (something unironically asserted in the video).
Harman is the only major audio company that releases its research to the public for free, and that's soon going away thanks to new policy. It's no surprise; that free research ends up being bad press for them when people who fundamentally misunderstand or mischaracterize it go on to attack Harman for daring to assert that there ought to be a standard for comparing measurements between test sources.
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15192582
It will depend on your budget of course.
Personally In terms of stuff under $1000, my recommendations would be:
MH755 if you can find a genuine set ($25 ish)
Tanchjim Tanya (~$40)
Moondrop Aria ($80)
Moondrop KATO ($190) - These things are really worth stretching to if you can. They punch so hard above their pricepoint it's kinda ridiculous and they make most stuff even several times their price seem somewhat pointless. Either cause these are better, or cause the other stuff is so tiny of an upgrade it'd be pointless to pay the extra
used UM MEST MK2 (new $1500 ish but can be found used for ~$900)
If you have unlimited money, best I've heard are probably either the Anole VX or MAD24 depending on what sort of sound you prefer.
Video reviews: https://youtube.com/goldensound and https://www.youtube.com/c/TheHEADPHONEShow Written reviews and measurements: https://goldensound.audio
Current Main Setup: Roon -> HQPlayer -> Holo Audio May KTE DAC-> Holo Serene KTE preamp -> Benchmark AHB2 (Speakers) / Zahl HM1 (Headphones)
Most used headphones: Hifiman Susvara, Abyss 1266 Phi TC, Sennheiser HD800-S, ZMF Atrium
Speakers: Focal Sopra No3 + 2x SVS SB-16 Ultra
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15193031
Kbear KS2 are killer IEMs on a budget
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15193425
For my buds - I get semi-disposable ones... the AKG buds that come standard with the Samsung Galaxy phones - so I get 4 pairs for £10 on eBay... I literally leave one pair in each jacket / bag...
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
https://linustechtips.com/topic/1401767-best-wired-earbuds/#findComment-15194423
