Hello All!
     With AMD's launch of the new AM1 platform, I figured id build a project I had been wanting to do for a while now. The price was right, and everything should fit!
I dont have everything yet, the Pico PSU and hard drive are still on their way.
(Note: Yes I know there is an asrock board with a built in 19v power jack, it is just more expensive then the combo deal with the Elite 130 case)
I decided that until the PSU and SSD came in, I would just build it into the case to play around with the APU and verify that everything worked.
Sorry about the picture quality, ill be getting a better camera soon!
I was surprised it fit so well! Now just to figure out rear IO and airflow.
Please note that this is a temporary setup. Absolutley no time was put into cable management as this will be dismantled in the next few days.
Also, if anyone wants to see benchmarks or gaming performance on the 3850 let me know!
Thanks for looking!
Mobo: MSI 970a-G46 CPU: FX-6300(4.5ghz @ 1.514v) Cooler: CMHyper212 PS: Raidmax 600w (80+) Case: CM Haf912 GPU: Sapphire 7870Ghz Ed. (1.3ghz @ 1.300v)
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/
Why did you cheap out on the sempron  :lol:
Also no mousepad y_u_no_mousepad-r16cbff80a67b421c87a08e1
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870084
Haha the combo deal came with the elite 130 for $99, so im just going to sell the sempron to my brother and grab the 5350 with an MSI board for $80. So we both win!
Also EDIT: Not my main PC, this is...
and I have this mousepad!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870102
Some older paid for/freeware/abandonware DX9 Gaming titles would be a good indicator of performance for retro builds/classic gaming. If possible.
No SSD? <- Not making it be as fluid and responsive as any other CPU in general usage....
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870110
Will do, the 3850 can play minecraft at 30fps on fancy graphics, with an 8 block draw distance. Runs surprisingly smooth! Much better than my girlfriends i3/HD3000 graphics
Yup! Its on its way!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870133
I dont see any pics'
hmm, that is odd, here is the imgur album, that should work! :)
http://imgur.com/a/FJn1u
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870154
Give us some benchmarks :)
This is a smart use of low power small form factor components.
You will probably end up cutting holes on the box for airflow.
2014-04-15 13:32:59 - csgo
Frames: 2328 - Time: 79171ms - Avg: 30.405 - Min: 23 - Max: 84             @medium settings 1680x1050
2014-04-15 13:36:34 - JustCause2
Frames: 2443 - Time: 92025ms - Avg: 26.547 - Min: 19 - Max: 38              @low settings 1280x720
Torchlight ran an avg of 35fps @medium settings 1680x1050
Getting some more later!
-Bioshock infinite
-Supreme Commander 2
-etc.
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1870601
I need that mousepad in my life, where did you get it? ;D
Main Rig: Cpu: Intel Core i7 4790k CPU Cooler: NH_d15 GPU: Gigabyte Radeon HD7970 Windforce III MOBO: Msi Z97 Gaming 5 RAM: HyperX Fury 1600 8gb white SSD: Samsung 840 evo 250gb PSU: Corsair CX750M Case: NZXT H630 white
PC peripherals: Monitor: Samsung Syncmaster T27B550 Keyboard: Logitech G105 Mouse: Logitech G700s Headphones: Logitech G430
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1871266
Sims 3 @1366x768 if you can =D
I didnt have an option for 1366x768, so I did 1280x768
2014-04-15 21:22:40 - TS3
Frames: 1945 - Time: 57471ms - Avg: 33.843 - Min: 22 - Max: 46 (Medium settings)
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1873137
Its one of the artscow $.99 mousepads! I just used some of my favorite brands! :)
I can send you the design if youd like to order one yourself!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1873150
yes please do, glorious pc master race
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1874457
Wait, wat? are we talkin about the iGPU O.o?
(Then it performs like mah 8500 GT xD)
That was the closest resolution I could get. haha.
Yeah it definitely isnt anything revolutionary, but for its size its pretty sweet! The 5350 is on its way, ill post comparisons between the two so you can see the performance gain going for the more expensive processor.
Here you go!
http://www.artscow.com/gallery/mousepad/logo-bgc4xu17wcf1
The logos on there are
-AMD
-Steam
-Android
-Aperture Laboratories
-Audio Technica
-Taurus Firearms
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1876332
Not bad for a little guy. I would still rather see a 4-pin mounting system, like Intel's.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1876684
Yey! I can't wait for it, I suppose it's going to be in the same post so... *subs*
Its coming in today! So ill post results later tonight :)
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1881982
Do you own a 210? (for comparisons LOL)
A 210 what? haha itll be a little longer :( gotta reinstall windows due to new processor >:(
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1885081
poor sized pictures
The other motherboard I was using needed the notch in the middle, this one doesnt  :(
Just gotta mount the power jack to the metal mesh when I put that in!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1885123
Very nice.  I quite like the old steampunkish builds. Keep up the good work mate!!!!
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1886793
You don't have to reinstall windows if you're only changing your CPU... :huh:
ASUS_NVIDIA_GeForce_210_silent_graphics_
Oh! That one! haha ill look up the performance specs and see if I have anything close :)
Thats what I thought too... but windows 7 wont even boot :( I tried fixing the MBR and some other things, but ill just put windows 8 on it. haha
Thanks man! It still isnt finished, and theres still quite a few things that need attention. Its getting there though!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1887620
All done for the most part! Just have to refinish the wood and do some cable management!
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1913108
Looks pretty cool, but what do you plan on using it for, LAN parties or did you just make it for fun?
Future build:  Obsidian 450d, G1.Sniper z87, R9 280x Core i5 Haswell cooled by H100i, HyperX 8gb, Crucial SSD 120gb, Barracuda 2tb HDD
Current build: HAF 912, the worst mb ever, r9 280x, Core i5 650 w/ stock cooler, Corsair Dominator 4gb, 500gb Western Digital blue
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1916783
AMD has brought a new really cheap way to make a PC. Also like the build, cool idea
CPU-- AMD FX-8320 (Stock), Motherboard-- ASUS M5A99FX PRO R 2.0, RAM-- Team 8gb 1600Mhz, GPU-- Sapphire 7870 GHz with OC Edition, Case-- NZXT Tempest 210, PSU-- Corsair CX600m, HDD, 1tb Seagate & 2tb WD External, Monitor-- Dell S2240M IPS Display, Keyboard/Mouse-- Some Logitech keyboard and some Dell mouse, Speakers-- Logitech Z533
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1918157
Nice I/O shield solution :P
PS: what settings on MC?
haha thanks! That took the longest out of anything. Lots of cutting and grinding!
I had it set to fancy graphics, minimal smooth lighting, and particles decreased. with a 12 block render distance :)
If I don't sell it, I will probably put my 5350 in it and hopefully use it for the steam in home streaming stuff!
Thanks man! Yes they have, its pretty sweet!
I have a few more mods to it that i'm doing before its completely finished, but its pretty close to done.
https://linustechtips.com/topic/140142-am1-based-cigar-box-pc/#findComment-1919557
