Overclocking the 8320 multiplier strange issue
I was really hoping that it wasn't the VRMs. I'd recommend RMAing your board, there is a sticker on the box which includes the serial number for your board, if this sticker is undamaged then you can still RMA your board.
Top-down CPU coolers like the Notcua NH-C14 will also help with the VRM cooling.
Update 2:
Did what I said before about reorienting the cpu cooler to not blow warm air over the VRMs and have the rear fan become intake fans. It helped abit but the temps were still in the 100s.
So I did some research and found out that prime95 does something so that the OS doesn't cut off the floating point calculations and that really overtaxes the CPU, something that'll never happen in real world scenarios (at the time HWinfo64 is showing that the VRMs are pushing 140amps). That in mind, I decided to switch to AIDA64 for stress testing and now it's all good The VRM temps max out at 83C and are pushing on avg 98amps while the CPU is at 100%, and not throttling. So you can still recommend the 990FXA-UD3 I guess, as long as they don't stress test with prime95.
