What does port forwarding do?
Port Forwarding sets up public services on your network such as web servers, FTP servers, e-mail servers, or other specialized Internet applications. When users send this type of request to your network via the Internet, the router will forward these requests to the appropriate computer.  For example, if you're hosting a website you'd open ports 80 an 443.
As for gaming,
Port forwarding – or creating a port forward – is a common process in gaming that makes your gaming console or PC more accessible to other gaming consoles or PCs on the Internet. Port forwarding can improve connection speed, lobby wait times, and overall gameplay, particularly for a host
Its worth noting that in most cases this is done automatically via a feature called uPnP (Universal Plug'n'Play).
Devices/applications that support uPnP will negotiate with uPnP compatible routers (pretty much all consumer routers) to automatically setup the port forwarding.
So 90% of the time you don't need to do anything. If youre talking about the likes of an Xbox or PS you can run a connectivity test which will test if active connections can be made which indicates port forwarding is already configured.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
Already thoroughly covered above port forwarding is basically just a firewall exception in your router allowing external connections to talk to internal clients based on port number.
As for needing a Static IP this depends on weather you're talking about the end devices IP or your routers public IP address. In the case of your end device you would indeed want a static IP but you also don't want your router trying to hand out that IP to a different client so it's recommended to either shrink the DHCP pool in your router or use your router to reserve that IP for the end device.
As for your Public IP. Ideally you don't want this to change either but requesting a Static IP from your ISP can be either an additional fee or not supported by your ISP when on a residential connection. In either case look into services like No-IP. This is a Dynamic DNS service that let's you use a domain name and automatically tracks your ever changing public IP.
There's other issues you can run into with port forwarding such as being trapped behind NAT or NAT64-CGNAT where you either have to change your router setup or change ISPs respectively (Or explore VPN/VPS services) but that's not immediately relevant.
