1080ti mining temp and hashrate question
Solved by tikker,
32 minutes ago, Bad5ector said:You have a -500 underclock on your memory? Why?
Pascal has a hardware problem that affects ETH mining. This makes it scale with core clock quite a bit and also a memory underclock sometimes helps more than a memory overclock. I've had this as well.
OP: setting you power limit to 56% sure won't help hashrate. Doing other things that use the GPU also doesn't. What model card is this and what are you getting at stock settings? 35 Mh/s, up to 40 on good days for me is more or less where it's at though.
My 1080 Ti FE is doing ~31 at this moment with 80% PL, core +200 and memory +500.
