Hi CPU temps?
Hey, new to the forums here. >.> Anyway, I have a FX-9370 running at the stock 4.4. .I have Turbo disabled and am Cooling it with a Swiftech H-220 in a Cosair 750D case. At idle regardless of what I set fan speeds to I sit around 44°C.. under minor gaming loads it jumps to around 55°C, and under a synthetic load it skyrockets to over 70°C in a matter of a couple of minutes (And I've not tried letting it go past that). My room is maybe only 20° +/- a couple degrees. I've tried swapping the fans for Cosair SPs, tried push, pull. and push/pull. Tried reapplying thermal compound and reseating the block.. nothing seems to bring the temp down on this thing. 44° Idle seems high to me, but I thought I'd ask others... Thanks in advance
what motherboard?
Known Motherboard incompatibility issues
- Asus Crosshair V Formula-Z AMD 990FX Motherboard - Interference with VR Heatsinks
- ASRock Z77E-ITX LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard - Interference with RAM & VGA slots
- ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb/s USB 3.0 SSI EEB Intel Motherboard - Interference with Ram slots closest to CPU sockets - Can only use outer RAM slots.
verify the block/pump is installed flat. might have to remove and check TIM pattern
to verify install is good.
