Vertical bracked + arctic xtreme iv
Solved by CableMod,
@JonaHUN the CableMod vertical PCI-E bracket (PCI-E 4.0 version available) will support a 4 slot cooler, the IO plate at the rear of the card is a 2 slot (2 slot IO photo attached), correct? If so you'd be all good to go.
https://store.cablemod.com/product-category/accessories/vertical-pci-e-brackets/
Featured Topics
1
EzioWar 路
Posted in CPUs, Motherboards, and Memory1 -
Zham 路
Posted in Troubleshooting9 -
Darth Destiny 路
Posted in Graphics Cards4 -
2
Shadow1789 路
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
