G PRO Bottlenecking Double-Click Speed
Solved by TheChromaBristlenose,
The GPW and G403 used to share the same debounce time, but Logitech increased the former's to 94ms (up from 44ms) during the HERO 25K firmware update to address the plague of double-clicking issues. Theoretically 47ms is the minimum possible time between clicks, but the Codepen site measures time between mouse-downs, so the minimum click duration (also 47ms) has to be taken into account with the final number.
Long story short, yes, there's a real and measurable difference between the two when it comes to debouncing. Unfortunately there's also no way to rectify it, since Logitech does not provide any way of downgrading firmware on their products.
