3 minutes ago, Wictorian said:
First, how can I display the text?
Assuming you're doing this in something like Tkinter, as a label
And how can I deal with punctiation?
The text is coming from a predefined string -> punctuation will create some special cases but really there's not much to miss
https://linustechtips.com/topic/1382198-speed-reader/#findComment-15054680
I guess it will be okay, I want to make it readable.
It will display one word at a time. Should it display one piece of punctuation at a time too? Or should I merge it with the previous word?
https://linustechtips.com/topic/1382198-speed-reader/#findComment-15054694
That’s what labels are for
That’s up to you to decide, it’s your software
https://linustechtips.com/topic/1382198-speed-reader/#findComment-15055160
I'd merge it with the previous word. Also, make sure to run your tkinter gui in a seperate thread, this will make your experience smoother and more responsible (the window or additional features like buttons may hang if both your gui and main code run in the same thread).
https://linustechtips.com/topic/1382198-speed-reader/#findComment-15058607
I have no idea how to do that.
https://linustechtips.com/topic/1382198-speed-reader/#findComment-15059236
