Pc upgrade help
Solved by RONOTHAN##,
https://it.pcpartpicker.com/list/HMRrTJ
It's about 30€ over budget, but it should be one hell of an upgrade. 5900X so you've got 12 cores with some of the highest single threaded performance out now, so you can run a lot of VMs off it. 32GB of RAM, I would have preferred it to be faster but I was really trying to fit a 5900X in there so some concessions had to be made. Very well rated 750w PSU so you won't have to upgrade it as long as you aren't gonna get like a 3090. The motherboard isn't the greatest, but it should be enough as long as you aren't overclocking like crazy.
