Massive GPU (10k score drop) Performance Drop - 3DMark. Need help understanding what's going on.
9 hours ago, SkilledRebuilds said:What is performance like with basic DDU troubleshooting.?
Aka Download (DDU) Display Driver Uninstaller.
Uninstall GPU Drivers NORMALLY via Windows first and Reboot.
Then run DDU and Reboot.
Reinstall Fresh Drivers for your GPU.
Test Performance (hopefully fixed without OS-ReInstall)
Thanks for your reply.
I tried your suggestion and unfortunately performance was still as before. So I opted for a clean install, reverted back to the latest stable version of Windows 10 (21H1 - build 19043.1266).
Performance shot through the roof, back to where it should be and all of the other problems resolved. So unfortunately, if anyone else is experiencing severely reduced performance on -- at least my version of 3080TI (EVGA FTW3) -- you will likely have to revert back to Windows 10 21H1 where performance is more optimized.
I hope this helps anyone who encounters a similar issue!
Updated result: https://www.3dmark.com/3dm/66827730?
Cheers!
