Want 2 upgrade my rig. need help w deciding wich cpu 2 buy.
Solved by Kotoezh,
Budget: 415 dollars
I play lots of games like r6:siege, apex, BF:5 and lots of other stuff. The point is - i also edit videos (AE) and make 3d renders/physics sim (blender).
I have 2 cpus in my sight (for AM4 socket): 3900x and 5800x. While 3900x has more cores - 5800x benches for single core are way higher.
I'm searching for help, deciding between them, cuz i rly can't understand wich will make more sence in that case.
Thank you in advance :)
My rig rn:
32gb ddr4 3200 cl16 (16x2)
750w thermaltake 80bronse psu
3070 slightly OC'd version
ryzen 5 3600
GIGABYTE B550M DS3H
cooler won't be a problem.
