Tips to improve laptop battery life, please.
Solved by Pixelfie,
1. No, the laptop will stop charging the battery and the power will be used to run the laptop. Once you unplug it it will start using the battery.
2. Yes, only do it once in a while for calibrating the battery. Once or twice a year, not more.
3. That helps a lot. My laptop still has 70% health after 3 years but my friends with the exact same laptop have like 40% after 3 years. Difference is I set a charging limit to 80 and they didn't.
