Framework thermal compound
Devryd
Hi
Has anyone got a framework yet and looked at the thermal compound?
I was wondering if using liquid metal might improve the performance and boosting behavior.
I am really looking forward to getting one, but they arent sold in europe yet
Just now, Devryd said:
Hi
I doubt it. The laptop is not thermally limited and the boosting behavior is right in line with how it should be. This is a power restraint thing here not a boosting and they are already running the intel chips at max allowed power envelope. So no liquid metal wouldn't do anything.
Good thing the cooler is designed good, but its a pitty you cant get a little bit more performance out of it.
4 minutes ago, Somerandomtechyboi said:
Cant you just use throttlestop or xtu and force max multi?
The cpu's in the system have hard time limits so this should not work.
3 minutes ago, Devryd said:
Can you do something like this on a locked CPU?
I didnt know that
It should not work but who knows no reports of it working however.
