Can i use rgb software to control my rgb fans on a motherboard without rgb header?
Solved by Eigenvektor,
12 minutes ago, YugeshYokok said:i saw cooler master fan that comes with a controller hub but it can be only control by it remote how do i connect the rgb to my motherboard so i can control by it's softare. i never used a rgb fan before so before buying them i want to how to control then in myu mobo
Which one in particular are you talking about? Unless it's an addressable RGB controller, you can't control it by software. Here's an example of an addressable RGB controller:
The RGB controller is connected to the PC via USB, so that it can be programmed by software. The LEDs on the fans are then connected to the controller. The fans themselves need to support ARGB.
