Another 3/4-pin fans question
Solved by minibois,
4 pin fans that are essentially 3 pin headers, that's quite strange and something I haven't seen before.
a 4 pin PWM fan can still be controlled with voltage control (3 pin), just with a lesser degree of precision than PWM (as in not a smooth curve, but a stair step curve).
11 minutes ago, Rosol97 said:And what even does the 4th pin in my mobo's headers?
"NC" stands for "No Connection", so the 4th pin on those 3 pin headers does nothing
