So, I've just built my first computer, and I would like to overclock my CPU, to get a little more performance. As I have never done this before, I wanted to get some advice and tips.
CPU: AMD FX 8320 (3.5GHz)
CPU Cooler: Cooler Master 212 EVO
Motherboard: MSI 760GMA-P34
Firstly, can my CPU cooler handle it? What sort of clock speeds would you recommend (I was hoping for 4GHz at least)? How should I go about doing it (I was planning on using AMD Overdrive instead of going into the bios)? What temperatures are safe (I've had it up to 60 degrees celcius before)
As much advice as possible please, I really don't want to mess it up.
---Jacob Whitehead---
https://linustechtips.com/topic/137173-need-help-overclocking/
not on that board. its got no vrm heatsink and its matx, i surprised it can run that cpu at stock tbh
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1822619
I didn't wanna put a video link on "How-To" because your motherboard may be different in layout and design than others from a single video.
So here is a big list of various video's on Overclocking a similar CPU (8350) in various boards/bios's.
https://www.google.com.au/search?q=how+to+overclock+8350&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&gfe_rd=cr&ei=exdEU7_-LsbC8gels4HQDw#q=how+to+overclock+8350&rls=org.mozilla:en-US:official&safe=off&tbm=vid
You should always look up your CPU as well, finding out voltages and everything possible so you do not guess at ANYTHING.
If you have to guess on something, google it/youtube it, or ask here.
In saying that, cheap boards can overclock, but can fail a lot sooner, possibly taking out other components. This is why the above poster warns you to not bother...
I'm inclined to say the same without a good motherboard or vrm cooling options... (bar throwing more fans in the case for airflow)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1822626
you wont have any issues with the cooler ,it 'll perform great, the mobo , i don't know ,might not handle it ,i say wait till you get a motherboard that's overclocking optimized ,or ,don't go too far with this one
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1822689
Id get some beefy heatsinks first for your VRM. The 212 is more than capable
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1822847
Board not really suitable. See if you can just bump multi don't even touch voltage.
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1829382
its not just the heat from the vrm that matters, its how clean the power is when it comes out of them. a cheap board with few low quality vrm's will have much much more ripple than even a mid range board like the ud3.
Rig Specs:
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1829491
@Jumper118 what does ripple current coming out of the VRMs affect when OC'ing? Stability or max OC? I've seen some videos on Maxxarcade's channel on youtube, on some very-budget gaming build where he used some crappy 1155 boards on some sandy bridge Pentiums, and still got some great OCs out of them for what they are. I mean, I get that heat is bad for the VRMs, but the CPUs, correct me if I'm wrong, but don't they have capacitors on the bottom of them, the little tan things on the flipside of the die, for the sheer purpose of filtering out noise in the current going to the CPU? Mind you I'm a total N00B when it comes to overclocking, I've only done one build where OC'ing was done, and that was(and still is) a quick and dirty OC, with the voltage is set to "auto" because I didn't want to have to spend 7 hours screwing around with BIOS settings, and have yet to have any stability problems, I am just trying to gain knowledge from someone who knows more than I do. Thanks in advance.
Ripple affects both stability and max oc. It can also kill yout cpu. Ocing an intel pentium is very different to ocing a 8 core amd, its 125w when its stock which is double the pentium and uses a much higher voltage and current. The power phases are very important for ironing out any ripple and on old, cheap matx boards they will be lower quality and there will be fewer of them to keep cost down, the problem with this is that it will have more ripple at lower voltage, have more internal resistance, which will make it get hot and inefficient, so that you need to use even more voltage to get a higher oc. Also 1155 is a much newer platform and so the boards will use better components as well as pc parts progress a lot over a short space of time.
Rig Specs:
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1832041
I think I learned more in the 30 seconds that it took me to read that post than in my whole time working at the shop I work at. Props to you good sir. :)
thanks. i like to think that i know a fair bit about overclocking, but usually i'm not good at explaining things in words.
Rig Specs:
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1834066
There's no way in hell I would overclock an 8 core on that board
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1834294
i would tbf, but i wouldn't recommend it :P
Rig Specs:
https://linustechtips.com/topic/137173-need-help-overclocking/#findComment-1834574
