PC shuts down after a few seconds after removing CPU-cooler
9 minutes ago, Mel0nMan said:So... you literally removed your cooler while your CPU was running Cinebench (probably the highest load it has ever and will ever be under)? Yeah, it definitely would have shut down to prevent damage (although it could have still been a bit damaged). You definitely screwed up your CPU, but it's hard to tell whether it was because of the paste or because of the overheating. Sadly there's not much you can do unless you or a friend has another CPU or board to test with.
OP accidentally got some thermal compound on the pins and cleaned it off. Then OP wanted to see if the PC would boot, so reinstalled the CPU without the cooler to check. Then the PC shutdown while booting.
Compounding mistakes.
Take a deep breath, OP. It's gonna be fine.
Don't remove the CPU before cleaning it. And never boot a PC when the CPU has no cooler on it. Even just placing the cooler on the CPU without compound and without securing it would have been enough for the test you were trying to do, and you could still do that now to see that things are working.
