14 hours ago, Ramon Triton said:
Your onboard sound might be disable in BIOS. Make sure to enable it and then fetch the audio drivers for your motherboard on Asrock's website.
I beleve it is enabled, it was on auto setting, if i have the correct setting,
https://linustechtips.com/topic/1368363-no-audio/#findComment-14956261
