Just a quick question, how much does enabling all 8 of the cores on my i7 8th gen in my laptop effect my battery life.
https://www.amazon.com/Acer-Spin-Touchscreen-Quad-Core-i7-8565U/dp/B08QZ44DGR/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
there is the laptop if you want to take a look
oh and the laptop is brand new
https://linustechtips.com/topic/1361205-cores-effect-on-battery/
You cannot enable cores on a 4-core CPU to make it an 8-core CPU. The Core i7-8565U that is in your laptop has 4 cores and 8 threads and that is all it will ever have.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
Why?
If it doesn't need to use them all, it won't. No need to burn electricity for no reason.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Typically disabling cores will reduce battery life as the remaining cores have to work harder and longer to accomplish the same tasks.
If you want better battery life, start by disabling background tasks
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
