Best way to fix ugly text?
Netarangi
Hi all,
I hate the text that windows has:
It appears better in this image but it looks jagged and gross on my monitor. I have tried changing settings on my monitor, cleartype and nvidia control panel but I just can't get it looking good.
Are there any other methods I have forgotten?
What resolution is your monitor? It looks like it just that your monitor isn't high res which when showing small text like that will make it look blurry.
Opps sorry forgot the most important detail.. My bad.
I have a Gigabyte M27Q 1440p 170hz
Are you sure your resolution is set properly?
Also do you have the right drivers installed?
