Is my air mounted correctly
BulletSponge
I’ve watched some video about Aio mounting from gamers nexus and jay and I mounted my aio in my pc like this
Is this good mounting
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
Yeah that's fine.
EDIT: Question actually: Why do you have an exhaust and intake on the top of the case? You'd be better off having them both in the same orientation to keep a smooth flow of air. Generally, having them as exhaust is the best setup so air comes in from the front of the case and exits through the back and top.
That looks like a good mount. As long as you have fans pushing air through the radiator, it is all good!
I had a guy on Reddit say this81E74D0D-151A-45CA-A77E-4E99F83881BB.thumb.jpeg.31a56e3c5d45e6e1a8121841d25e1522.jpegwhich completely contradicts GN which I doubt this random dude is correct
I wouldn't listen to him. The way you have it mounted is fine.
the guy on redit was prob high or somthing. nothing of what he said make sense.  also, change this
The most important thing you need to watch out for is, that one point in the rad is higher than the pump. Tube orientation is a secondary option.
And well... dont listen to sole random shit on the internet if 2 big youtubers made a  vid about something of which is very indepth
Ping me or quote me in replys ples. Anyone talking about AiOs and trashing people for a front mount watch THIS JAYZTWOCENTS VID because u 99.9% skipped or didnt understand the Gamers Nexus vid...
Also pineapple doesnt go on pizza
At least move that top intake to as front as you can. Now its probably pushing in air that gets exhausted by the fan next to it.
Your cooler set up is fine. Change that other top fan to exhaust
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
I would run that setup. That intake at the top is cooling your ram, everyone likes cool ram 🙂
AMD R7 5800X3D | Thermalright Frost Commander 140, TY-143
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Not to mention having three intake and two exhaust ensures partial positive pressure which helps keep dust out. In order to keep the positive pressure when changing both top fans to exhaust, OP would have to make the rear fan intake, which would again be bad for dust as the rear fan slot doesn't have a dust filter (I'm assuming the top and front intake does have a filter). I have my fans set up the same way for that reason.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
I am all about positive pressure 🙂
Cant escape the dust though, so sweep your floor and vacuum your carpet 😄
