why doesnt my script work when i copy it UNITY
i have a car game
i have a coin collector script that works fine in the first scene. so i copy the whole panel to next scene, and i get this error. Everything i EXACTLY the same as the first scene. why doesnt it work?
i have attacthed the script that was in the error
i used this tutorial https://www.youtube.com/watch?v=gDHUsbE8nCw&t=0s
thanks
1111.png.cacbd47e856a2204858f7fa8d011957d.png111.thumb.png.e6350b2425bf759f0c63faf8e16815b9.png
"Object set not set to an instance" means you are referring to something that hasn't been made. It has been declared, but an instance does not exist of it.
Have you added the text to the script in the inspector?
Such as here:
Go to your scene, go to the object you have applied the PointsScorer.cs script to, look for the script in the inspector and then look at "myScore", where you have to apply the point text field.
This is explained at 12:57 of the tutorial:
