Running a Python script
Go to solution Solved by igormp,
Remember to add the shebang at the beginning of your script:
#!/usr/bin/env python3
Hi everyone,
i am writing some basic shell commands for my kali Linux (in python) and have them saved as .py files on my "desktop". Since I am new to python I don't really know how I can manage this, so my problem is: When I double click the .py file it opens in Code - OSS and I have to click "run" for it to actually execute the script. Is there a way to have the script running as soon as I click it in on my desktop (doesn't have to open a window or anything, it would be perfectly fine to do what it does in the background without notifying me).
Thanks in advance
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1354711-running-a-python-script/
Chmod +x is what you want.
alternatively, python files run native in the terminal environment on Linux
Now it has the "executable" checkmark and terminal as its default application for opening. However if I double click it now nothing happens (in this case it is a script for WOL, but the machine doesn't start). As soon as I open it with Code - OSS and click run, it works, when I execute it manually in the command line, it works as well.
OS: Windows 10 Pro
OS: Kali Linux
Well what does the program do?
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
well, start a computer with a magic packet. WOL
OS: Windows 10 Pro
OS: Kali Linux
That made it work, thanks.
OS: Windows 10 Pro
OS: Kali Linux
