100mbit through 80m cat6 cable
Make sure the order of the wires is the correct one. It matters.
The cable tester will only test if the colors are in the same order on both connectors, not if each color is in the right slot.
Use either one of the below on both connectors of the cable. T568B is more common and more used by patch cable manufacturers.
Also just in case you're using CCA cable (copper clad aluminum), which is poorer quality and has higher resistance therefore needs more power to send data, go in your device manager on your network card, properties, advanced properties, and set all the power saving featurs (ex green ethernet etc) to Disable. Your network card will consume half a watt to a watt more power but send the data through the cable at full power.
