Ryzen 7 2700x idling around 60c, I have an h100i elite capellix aio cooler and txm50 thermal paste. I also have a rm850x so I assume the psu cant be the problem. I included some pics, anybody got any ideas?
3 minutes ago, RONOTHAN## said:
What are the temps under load, and are you running any overclocks?
Under load it goes a little over 62c. I tested by loading a gpu heavy game, I dont know how to test under load yet. And no im not doing any over clocking I think
Run Cinebench R23 on a loop for 10 minutes, it's a solid all-core load without being crazy overkill like Prime95.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Okay so, I did it and my cpu hit 85c and then my icue fans and cpu rgb started blinking red and my fans started kicking in
Run Cinebench and check how much power the CPU is drawing using HWINFO.
This is fine. The Zen+ has a throttle temp of 95c.
3 minutes ago, _DeXTeR_ said:
Depend on case maybe  bad airflow and try to mount your AIO as intake on front side of case
I second this recommendation. I had to do this with my 240 aio on my 9900k to get good temps before going full custom loop.
