Does my 24pin replacement cable work with my PSU?
Solved by seon123,
No
https://www.corsair.com/eu/en/psu-cable-compatibility
You have to get any Corsair Type 4 cable. Here is the listing on Corsair's EU website. Click the "Find a Retailer" button to see if it's available in your area. If you're not in Europe, you could still look for the cable, or you could contact Corsair customer support.
