2 hours ago, Hivendo said:
W30, L20 and D35 in cm
H200i would be the one that i could think of to fit an actually powerful GPU, but something like Silverstone RVZ-03 can provide a better cooling.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
A small case that can fit a rtx30 series GPU?  I think it would depend on your definition of small. With what you gave it sounds like a HTPC (home theater personal computer) case is what would work best for that size.
Would need to know budget, amount of SSDs and HDDs, motherboard form factor (itx, ATX etc).
Yes and no. That case does will until your temps start to go up. Once it does there is a little bit of a.. thermal runaway.. that happens to the PSU. Sounds weird, but when I'm playing around with PBO it's usually my PSU that trips OTP
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Thanks for all the feedback. I was considering something like Sharkoon QB One but the Silverstone RVZ03 seems to fit better. Budget is around €700 without the GPU. Other components would like something like this. If I can get some of these from the used market, I'll be within budget.
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor
CPU Cooler: Noctua NH-L12S 55.44 CFM CPU Cooler
Motherboard: ASRock H570M-ITX/ac Mini ITX LGA1200 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive
A case like the NR200 might also fit well here.
