GTAV Lag spikes and slow loading textures!
M8ght
So, i've been playing GTA V for a while now, and i recently got my new pc wich should run GTA V semi okay-ish, but i'm getting wierd lag spikes and slow loading textures, wich is not a problem for my friend who has a config that's close to mine, so i dont know if anyone found a solution for this allready but, i do appreciate all the help i can get, to get rid of this...... problem!
Specs:
CPU: ryzen 5 3500x
GPU: GTX 1050 ti 4gb
RAM: 8gb of maybe 2666mhz
Storage: 1tb HDD
Running the game with much more than all 'Normal' settings in terms of textures, post-processing, etc. isn't really necessary, so I'd recommend setting that (especially with those specs).
I don't think the issue necessarily resides within your specs exclusively, it's probably just a combination with your in-game graphics settings.
Although I will say that only 8GB of RAM can definitely be an issue in 2021.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
Specs:
CPU: ryzen 5 3500x
Storage: 1tb HDD
put the game on an ssd and try to lower the settings a bit as your memory is only 8gb but firstly try putting on an ssd which you should have
Yeah, GTA really does needs a lot of disk bandwidth along with pretty good system. I had this issue too and the bandaid way is to decrease draw distance and keep textures settings on high (because medium and very high is literally downscaled high texture and upscaled high respectively), but at the end you really need to alleviate the bottleneck by moving your OS away from just a single HDD to a boot SSD.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
Thanks for all the replies! I will try to get an ssd for the boot drive and get more ram, but i've been tweaking the graphics and.... well, the slow texture loading is still there with high speed, but the lagg spikes ARE gone!
So..... yeah thx for the replies and the tips!
