Decided it's upgrade time seeing that 3080s are down around $2000 CAD these days. 7700k is going to massively bottleneck?
Gaming only. i7 or i9?
Have 32GB @ 3000 mhz
Intel fanboy.
I'm not a tweaker or gamerz so take that in mind for the mobo.
Is a $1500 CAD max budget realistic for something decent?
Desktop 1: 7800x3d @ stock, 64gb DDR5 @ 6000, Asus 5090 Astral OC, x670 Asus Strix
Basement TV Desktop: 7800x3d @ stock, 64gb DDR5 @ 6000, 4080 Super, x670 Asus Strix
Laptop: Dell G3 15 - i7-8750h @ stock, 16gb ddr4 @ 2666, 1050Ti
Laptop 2: Intel i7 12700k, 3080TI 32gb DDR5 Ram
Laptop 3: Intel Core Ultra 9-275HX, 5080, 64GB DDR5 5
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/
Intel fanboy.
ONLY a motherboard & CPU...?
What resolutions/refresh rates, as the CPU is partially/somewhat responsible for that bit...?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/#findComment-14799669
My bad.
My monitor is 34' ultrawide 1440p @ 120 hz.
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/#findComment-14799674
11 minutes ago, Andreas Lilja said:
My bad.
I can't see a lot wrong with this as a foundation:  https://ca.pcpartpicker.com/list/Lgxgx6
EDIT:
CPU cooler will depend on the case you use/get, but...
Edited by Eighjan
WHY NOT...?!
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/#findComment-14799686
Looking good, especially since I already have a decent cooler. (Kraken X62)
No reason to opt for more recent i7-11700K?
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/#findComment-14799691
Only that 10th Gen. seem to get more favourable reception than 11th; from what I've seen.
Differences are marginal for the extra spend.
WHY NOT...?!
https://linustechtips.com/topic/1346908-need-a-cpu-and-mobo/#findComment-14799699
